Jira-CLI with SSL causing issues
Andrian F
Hi All,
Trying to setup jira-cli with a production JIRA instance using SSL. I keep getting the below error when trying to run a CLI command.
Ex:  ./jira.sh --action getServerInfo
Client error: Invalid request: javax.net.ssl.SSLProtocolException: handshake alert:  unrecognized_name
https://bobswift.atlassian.net/wiki/display/ACLI/How+to+deal+with+https+and+SSL+problems
Above Bobswift documentation suggests that I add a "ServerName" setting in apache configurations. I have added it as below in the httpd.conf file. But i still keep getting that ERROR.
I tried adding below one at a time
ServerName servername:8080
ServerName ipaddress
 Anyone facing similar Issue ?
Thanks for reading
Andrian
Andrian F
Resolved the issue by using
http://localhost:8080 inside the jira.sh file instead of using the domain name, since i was already inside the server.
@Nic Brough [Adaptavist] Thanks Nic for making me realize to use localhost.
Nic Brough -Adaptavist-
January 17, 2017
If the server is secured with SSL, then yes, you'll need the right certificates, irrespective of source.
I usually terminate SSL at the proxy, so when I'm on the local server, it won't kick in because the proxy handles the ssl.
January 13, 2017
It looks like you're trying to reach an https based server?  You'll need to have the right certificates for that (and it probaby explains why your four server names don't work - none of them are https addresses)
Andrian F
Yes Its a https server.
Thanks Nic.
Let me try that
