Jira Cloud - Requirement Management - Project Management
Christina Stergiou February 27, 2019
Hi!
I work with Jira cloud in its basic form with no add-onns for Requirement management or Project management.
Which is the best way to have requirements and features in Jira in order to  track them and be transparent to the business also?
Is anything like Structure (that is not available for Cloud)?
Or any add-onns that will help?
Chris
3 accepted
Dave Rosenlund _Trundl_
Hi, @Christina Stergiou.
FYI, Structure Cloud will be available soon. And, you can try it out now by joining our Structure Cloud Early Access Program if you wish.
That doesn't change the other options highlighted by @Joshua Shang and @Taranjeet Singh, I just wanted to make you aware that Structure is a possibility, too.
Hope this helps,
-dave
Dave Rosenlund [ALM Works]
Christina Stergiou February 28, 2019
Thanks! Good to know!
Taranjeet Singh
@Christina Stergiou You could either use integration capabilities of JIRA and Confluence for requirements management. See this documentation for more info: https://confluence.atlassian.com/jirakb/using-jira-for-requirements-management-193300521.html
or
I found an add-on for requirements management in JIRA Cloud. See if this suits your needs:
https://marketplace.atlassian.com/apps/1217241/rmcloud-requirements-management?hosting=cloud&tab=overview
Joshua Shang February 27, 2019
For requirements management, it's best SDLC practice to use Confluence.  That way, your requirements stay constant while your user stories, tasks are in jira projects.  (You don't want to be sifting through closed tickets to find a requirement.)
For project planning, try Big Picutre, it has a fairly good Gant chart.
Thanks!
I have already linked Requirements from Confluence to Jira issues, I was wondering if there is something more advanced in cloud like structure...
mkazakov89 January 31, 2025
If you are still looking you can try NewSysRS Requirements Management for Jira Cloud. It has specification structure.
https://marketplace.atlassian.com/apps/1234976/newsysrs-requirements-for-jira
