Jira Cloud/Tempo Power BI Access Token
Sander Vanstaen June 25, 2021
I'm setting up my Jira to Power BI connections.
So far so good, I can pull all my Jira Data into Power Bi without any issues.
But, we are using the Tempo Planner plugin for resource planning purposes.
I would like to send this data to Power BI as well.
When I go to the Tempo tab inside my Power BI connection in Jira I get the error:
'You haven't added the Access Token.'
I did however add a token in the settings of Tempo
What am I doing wrong here?
Thanks in advance!
Kr,
Sander Vanstaen
Liubov Topchyi
June 25, 2021
Hello @Sander Vanstaen ,
To add Tempo Client Id and connect two applications, please follow this guide: https://aserve.atlassian.net/wiki/spaces/PBCFJC/pages/1594064929/How+to+add+Tempo+Client+ID
Please let me know if this helps. Thank you!
Luba
