hi, all, when I use jira Data Center 7.4.0 for a long time, I got the exception:
errorId=3f59fe3a-572f-4261-aa85-2c3c0f0b00aa, interpretedMsg=, cause=java.lang.NullPointerException: config, stacktrace=java.lang.NullPointerException: config
at java.util.Objects.requireNonNull(Objects.java:228) [?:1.8.0_45]
at com.atlassian.jira.issue.fields.option.CachedOptionSetManager.getOptionsForConfig(CachedOptionSetManager.java:42) [classes/:?]
at com.atlassian.jira.issue.fields.config.manager.IssueTypeSchemeManagerImpl.getIssueTypesForConfigScheme(IssueTypeSchemeManagerImpl.java:272) [classes/:?]
at com.atlassian.jira.issue.fields.config.manager.IssueTypeSchemeManagerImpl.getSubTaskIssueTypesForProject(IssueTypeSchemeManagerImpl.java:265) [classes/:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [?:1.8.0_45]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) [?:1.8.0_45]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [?:1.8.0_45]
at java.lang.reflect.Method.invoke(Method.java:497) [?:1.8.0_45]
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26) [atlassian-plugins-core-4.5.0.jar:?]
at com.sun.proxy.$Proxy471.getSubTaskIssueTypesForProject(Unknown Source) [?:?]
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136) [?:?]
at com.atlassian.jira.quickedit.action.QuickCreateIssue.setSelectedIssueTypeId(QuickCreateIssue.java:510) [?:?]
at com.atlassian.jira.quickedit.action.QuickCreateIssue.doDefault(QuickCreateIssue.java:195) [?:?]
it sames that the db data has something wrong, can anybody help me to resolve the issue?
Hi Yanshuai,
Can you check this article - nullPointerException when creating issue editing issue move issue accessing the screen tab from the project
The stacktrace may not exactly match, but it looks like you're hitting into an issue with the Issue type Config scheme.
Follow the query in the Diagnosis section and if you do get no matching values for an optionid to an issuetype id in the issuetype table then you can follow the Resolution section for it.
