Jira Export Issues - All Columns Not Showing
Jukka Hilvonen March 5, 2014
Hi All,
I have tried to export my searched issues to PDF, Excel and in Printable form so that the exported document would also show the columns I have included in the search results, but which are not normally there (namely Business Value and Story Points). For some reasons, the exported documents don't include BV and SP columns.
Is there an easy solution for exporting all the selected columns as well?
thanks!
- Jukka
Jukka Hilvonen March 11, 2014
Hi!
Thanks for the comments!
It seems that the problem has resolved by itself. I didn't do anything, but now the export includes also the columns which weren't previously there. Strange, but works.
- Jukka
Hi!
- Jukka
Hi!
- Jukka
Midori
March 5, 2014
Are you using the PDF View Plugin to export the issues to PDF? (I should be able to help with that one.)
No, I am using the default export-options which are available from the export button in the search list.
Xpand IT
March 5, 2014
You should try Xporter for JIRA. Let us now if you need any help!
