Jira Gadget for Mapping TestCases and Test Executions
Anna Ludwig March 1, 2018
Hey,
I am currently searching for a Jira Gadget to help me visualize TestCases per TestExecution.
Basically I need to map two Filter Results (all TestExecutions fors a certain time period and all the TestCases with a certain TestRunStatus.).
Does anyone have an idea for a Gadget that can map two filter results?
Thanks in advance,
Anna
José Domingues [Xray]
Hi Anna Ludwig,
The result can be achieve using the gadget Test Run List or the report Test Run Report with a preconfigured filter to select a set of issues to be displayed (for instance based on a time period). In the gadget itself it is possible to select the Test Run Status.
Best regards,
Xpand Add-ons Team
