Jira: How to change asignee after an issue is closed
Chris Chris June 26, 2012
I want to delete a Jira user who is no longer with the team because his username is taking up one of my FishEye licenses. However I can't delete the user when he has assigned issues, even though they are closed.
So I want to change the assignee of those closed issues to another person. Can I do this w/o re-opening the issues (I am looking at about 50 total issues)? Or is there another way I can delete the user
Jobin Kuruvilla [Adaptavist]
June 26, 2012
There is a workflow property "jira.issue.editable=false" in the Closed step of standard workflow.
If you remove that property, you will be able to modify the assignee.
You can also reopen, change the assignee and close it back!
Doug Varn
May 13, 2013
Jobin, this will only allow bulk edits of closed issues in future, not retroactively, correct? How can all previously closed issues be updated easily?
May 13, 2013
It will help with existing closed issues as well. Not just the future ones.
Joe Pitt
Don't delete the user, it will mess up your issues. You'll get an sql error in the history. Just move the user out of the jira-user and any other group with logon rights and that should take care of the license issue.
Vishali
May 13, 2013
Create a single username for all the terminated users 'termuser'
Create a filter with closed issues assigned to the user (who left) and do a bulk Transition of issues to a new status by choosing 'Do not send emails'.
Now bulk edit all the issues and change the assignee to 'termuser' and select 'Do not send emails'
Transition all the issues to closed status.
