Hi
I need to write a Groovy Script to create JIRA Ticket (A task) from JIRA Insight and I have never used this before so an absolute newbie.
Is there any resources for this and if someone has written something similar it would be of great help.
Regards
Can you elabrate more what need to achive.
HI
Yes I want to generate ticket based on expiry date. I have done this previously using Insight Automation rule. However, in this case the automation rule is not working as we have scriptrunner enforcing certain fields to be mandatory when creating a new ticket.
So my options are two -
a) Turn off the scriptrunner which I cant.
b) Use groovy script to acheive the above.
