Jira Installation on AWS
Naveen Singh
March 13, 2014
I am trying to standlone version of Jira on AWS instance. I am able to get the setup page through
http://your_elestic_ip_address:8080url, but after entering the MySQL database parameters, i get the error Could not connect to myserver. I see the jira database and table structures are created so no issue with sql connection. I restarted the Jira multiple times but still have the issue.
What could issue I am not able to go thrugh the seup process and see the license page?
Pavel Korsukov
Hi Navin,
It may be a tricky security configuration for AWS security groups, VPC and firewall. It is so complex that I would recommend to use the professional deployment services to get your JIRA deployed in minutes. For example, take a look on Deploy4Me https://deploy4me.com/en/install/jira.html
