I have 4 issue types, 3 system (Epic, Task, Story), 1 custom (Request) in my jira center project. I am trying to create an issue collector for Task but when it comes to the Issue collector form and selecting a template, I select 'custom' but for epic, task and story, its blank, for request, I see the fields I want. But I need to use the Task issue type.
As a Jira user when creating issues, i can see the fields on all issue types, but the issue lays when creating the issue collector.
Image below of what the template shows me when I select epic task and story and then when i select request.
Does anyone know what the issue could be?
The fix seems to be creating an issue collector using a basic template with the task issue type, then creating a 2nd with the same issue type which then allows me to add the fields.
