Jira Issue Collector in Salesforce
Gurpreet Sandhu August 13, 2019
I am trying to use Jira Issue Collector in Salesforce to gather the requests from our Salesforce Users whenever they have any issue with Salesforce.
Expectation:
Create a Button in Salesforce for example, 'Report an Issue', that should enable them to fill the information. This action should create an Issue in Jira.
Guru
Shubham Gupta
February 10, 2020
Hi Gurpreet,
Try Sinergify -- a Salesforce Jira Connector
I hope it helps.
Aidin Mahmoodi {ServiceRocket}
Hi Guru,
If you are looking for a more robust solution to also incorporate more interactive and automated approach, you can check out the Connector for Salesforce & Jira.
This app allows you to set up customizable mappings to capture information manually or automatically from Salesforce users on any Salesforce objects and then create associations that provide automated synchronizations between Jira and Salesforce.
Best,
Aidin
