Jira Issue Collector plugin not supported for pre-5.0?
Dave Drexler
Hi - I see that the Issue Collector plugin is now out of beta and officially supported, which is good, but it also appears that it is no longer compatible with pre-5.0 versions of Jira - that's Bad. Am I reading that correctly?
Has anyone tried installing and using v1.1 of the plugin with v4.4.5 of Jira? Does it work?
Dave C
July 14, 2012
Yep, you're reading it correctly - v1.1 of the Issue Collector is not compatible with versions of JIRA prior to 5.0. If you install 1.1 into an earlier version, such as 4.4.5 it won't start with an error about an unresolved constraint in the logs.
If you're interested in using the non-beta, fully supported functionality I'd suggest Upgrading JIRA to 5.1.
Dave Drexler
Hi John - I think you've misread my question. I was looking for a version of the Issue Collector that was compatible with **pre-5.x** versions of Jira.
We're currently using Jira v4.4.5.
John Chin
November 28, 2012
Hi Dave,
For your information, you may install issue collector plugin latest version in JIRA 5.0.x.
Please download from the following page:
  • https://marketplace.atlassian.com/plugins/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin
John Chin
