Jira - Issue Links and Pagination
oliver.peacey
Hi. Some of our issues have a large number of issue links which span across different projects. When the number of links is around 50+, this severely degrades the performance of the issue. For example, one of our issues has upwards of 100 links, making the issue slow to open and edit.
Is there a way of enabling pagination on issue links? In the same way that the 'Advanced issue search' uses it. If the links were split into pages, maybe 10 per page, then it would greatly improve performance for issues with a high number of links.
In addition, is there any way of sorting Issue Links by their identifier?
Best,
Ollie
Alessandro Lombardo
July 21, 2022
You should see a few links and then see the button "show more links". Don't you have it?
oliver.peacey
Unfortunately not, the issue is just listing the 100+ links one after the other
Alessandro Lombardo
July 21, 2022
I think that there's no solutions https://jira.atlassian.com/browse/JRACLOUD-41357 ( look at this )
oliver.peacey
Thanks for sharing. I can't see why this isn't a built in feature
