Hi
I am needing to set a label on an issue in my jelly script, I know how to get the labels, but I cant find anything in the javadocs that allows me to create a new label or get an existing label to set on an issue:
<core:invoke on="${issueKey}" method="getLabels" var="labels" />
<!-- Get or create a label -->
<core:invoke on="${labels}" method="add" var="flag">
<core:arg type="com.atlassian.jira.issue.label.Label" value="???" />
</core:invoke>
<core:invoke on="${issueKey}" method="setLabels">
<core:arg type="java.util.Collection" value="${labels}" />
</core:invoke>
Any help would be very much appreciated, thank you!
You can use the LabelManager, like this:
<?xml version="1.0" encoding="utf-8" standalone="yes"?> <JiraJelly xmlns:jira="jelly:com.atlassian.jira.jelly.JiraTagLib" xmlns:core="jelly:core" xmlns:log="jelly:log"> <jira:CreateProject key="XYZ" name="XYZ Project" lead="admin"> <jira:CreateIssue summary="Rocket thrusters not firing" reporter="admin" assignee="admin" issueIdVar="issueId" /> </jira:CreateProject> <core:invokeStatic className="java.lang.Class" method="forName" var="clazz"> <core:arg type="java.lang.String" value="com.atlassian.jira.issue.label.LabelManager" /> </core:invokeStatic> <core:invokeStatic className="com.atlassian.jira.component.ComponentAccessor" method="getComponent" var="labelManager"> <core:arg type="java.lang.Class" value="${clazz}" /> </core:invokeStatic> <core:invoke on="${labelManager}" method="addLabel"> <core:arg type="com.atlassian.crowd.embedded.api.User" value="${jelly.user}" /> <core:arg type="java.lang.Long" value="${issueId}" /> <core:arg type="java.lang.String" value="oops" /> <core:arg type="boolean" value="false" /> </core:invoke> </JiraJelly>
Is this possible without updating the updatedDate, too? e.g. the comment manager has a flag "tweakIssueUpdateDate".
