Jira Locks up when updating field with Jira Componate Watcher PLugin Enabled
Information Systems
When my user try to resolve an issue and update the fix version field during the transition it locks up JIRA causing to need to be restarted. If I disable the JIRA Componate Watcher Plugin it no longer locks up and everything works as normal. It there anything I can do help debug this issue?
Srinivasa Rajendra Pudi November 16, 2016
Hello ,
We are also facing the same issue after upgrading JIRA to 7.0.* version kindly provide us the solution if you found any for this, That would be great
Vasiliy Zverev
February 19, 2016
You should to report a bug to plugin developer.
