Jira Mobile Connect is not sending crash reports
Mark Steer
January 5, 2012
I just integrated JMC in one of our apps and it is not sending crash reports. From console I noticed errors like
[JMCTransportOperation connectionDidFinishLoading:] <JMCTransportOperation: 0x9a17d00> Request FAILED & queued item is not deleted. jmc-57620CE2-A80A-4E25-917B-49284EBE0E1A <?xml version="1.0" encoding="UTF-8" standalone="yes"?><status><status-code>500</status-code><message>com.atlassian.jira.project.ProjectManager.getDefaultAssignee(Lcom/atlassian/jira/project/Project;Ljava/util/Collection;)Lcom/atlassian/crowd/embedded/api/User;</message></status>
when I try to send a report.
Thanks.
Mark
Cassio Santos Pereira May 18, 2012
I'm having the same problem, but I'm using Jira OnDemand. Anyone have any ideas?
Louie Penaflor
Upgrading to JIRA 4.4 fixes it
Nick
January 12, 2012
Hi Thomas,
Are you able to try upgrading JIRA to 4.4 and see if that helps ?
There could be a 4.3 compatibility issue here.
Nick
Louie Penaflor
I am also having the same problem:
com.sun.jersey.server.impl.application.WebApplicationImpl onException
SEVERE: Internal server error
java.lang.NoSuchMethodError: com.atlassian.jira.project.ProjectManager.getDefaultAssignee(Lcom/atlassian/jira/project/Project;Ljava/util/Collection;)Lcom/atlassian/crowd/embedded/api/User;
I'm also using JIRA 4.3.4 and plugin verison 1.0.11. Any other fixes besides upgrading JIRA to see if it helps?
Thomas Haak
January 11, 2012
I'm having exactly the same problem. I also set permissons for jiraconnectuser to create issues in my project, but that does not solve the problem.
I am using JIRA Version v4.3#614-r144677 and version 1.0.11 of the plugin.
Thomas
Nick
January 5, 2012
Hi Mark,
That is failing due to some error with JIRA.
Which version of JIRA are you using, and which version of the plugin have you got installed?
Also, please check that the jiraconnectuser has permission to create issues in the project you are using.
Nick
