Jira SDK: fetching Jira issues filtered by custom field
Haitham Salem
May 11, 2017
i have an issue while fetching Jira issues filtered by custom field, i am getting below error:
Response Content: {"errorMessages":["Error in the JQL Query: Expecting a field name but got ')'. You must surround ')' in quotation marks to use it as a field name. (line 1, character 22)"],"errors":{}}
the code is:
var issues = jiraRestClient.Issues.Queryable.Where(x => x.Project == ConfigrationManager.JiraProject
&& x.CustomFields["Transaction Type / ATM Number"].Values[0] == "Deposit");
The custom field "Transaction Type / ATM Number" is cascaded drop down list it has two elements in value string array, see below picture
please help
Lucas Modzelewski _Lumo_
It's most probably outdated, but if you have an answer please post it :)
As for developer related topic there is a better place: https://community.developer.atlassian.com/
