Jira: Single View of Stories and their Sub-Tasks?
Ross Ryan
August 27, 2014
We are evaluating Jira as an overall agile tool (not just a defect tracker) and are currently using Rally.
In Rally, it's possible to see all an iteration's user stories with their tasks in a single view (a hierarchical list). Is this possible in Jira? I can view the stories on the Agile Board Plan Mode but not their sub-tasks. I can only view sub-tasks if I click into the story.
Ross.
Ross Ryan
September 16, 2014
This doesn't really answer what I'm looking for but thanks anyway.
Simon Kegel //SEIBERT/MEDIA
August 31, 2014
Hey there,
you can see the sub-tasks for each task in the work board.
The sub-tasks are the lowest level in Agile - the level of actually doing something.
This isn't important in the plan board if your stories are well descriped.
Example:
Epic - "Destroy the one ring"
1 Story - "Collect the fellowship"
1 Sub-Task of this story could be - "Find Aragorn"
Another "Find xy"
- Do you really need to see this in the planing?
So it's not thought to see this in plan board because its "just" the doing behind the to-do.
Hope this could help.
Greets
Simon :)
