Jira Structure Formula help (Parent Link summary)
Eugene Nechaev March 28, 2023
Hi All,
I have a question about how to get a Name of Initiative from Epic level in Structure Field Formula?
If I'm using Field Parent Link I have Jira ID - Summary
If I'm using this.ParentLink I have only Jira ID
My structure organized in a way that I have
Level 1 - fixVersion grouping
Level 2 - Epic's assigned to fixVersion
Level 3 - Stories assigned to Epics
All Epics assigned via Parent Link to some Initiatives.
Thank you.
Nicholas Ellis _ALM Works_
Hi Eugene,
If you group your epics by their parent link then you can do this very easily with a formula like:
if type = "epic" : PARENT{summary}
However I'm guessing you only want the summary without actually including the issues in the board.  If so I don't think there is a way to do this presently.
Nick [Tempo/ALM Works]
