I am trying to retrieve a Custom Field using the Jira Tableau Connector. This field uses the Group Picker, and instead of seeing the values shown in Jira, we see only “0” or null in the Connector.
Hi @[deleted], If you're using Tableau Connector Pro for Jira, please submit a ticket to our support team and we can help!
Thank you @Lisa Teves _Appfire_ I submitted POWTAB-456 through the help center.
The support center responded with the following:
The issue has been replicated in v4.7.1, but in v4.9.65 it is fixed.
Please update to 4.9.65 version and check if it works correctly for you.
I tested the new version and it resolves my issue.
