Jira Upgrade from Jira 3.9.2 to Jira 4.4.5
Angelica Castillo July 25, 2013
I need to perform an upgrade from jira 3.9.2 to Jira 4.4.5, can I do it direct? or I have to do many Jira upgrades? How many and which versions please?
Do I need any script?
I'll be using sqlserver 2008
Nic Brough -Adaptavist-
July 25, 2013
Script, no. But I would strongly recommend
  1. Export the xml
  2. Set up Jira 3.13, in a new empty database (i.e. leave the old one untouched, so you can always go back)
  3. Import the xml into there (Jira will upgrade it)
  4. Set up Jira 4.4.5 and point it at the 3.13 database
Of course, do this in test first! That will tell you how easy (or not) this process is.
hello thanks for the reply, well I'm getting an error installing Jira 3.13,
the doc. of upgrade 3.13 recomended to run this script
ALTER DATABASE jiradb SET READ_COMMITTED_SNAPSHOT ON
SELECT is_read_committed_snapshot_on FROM sys.databases WHERE name= 'jiradb'
I'm getting this error, that does not let me go forward.
Wrong Parameter Usage
C:\Users\isthmain-11\AppData\Local\Temp\i4_nlog_44
July 25, 2013
Ok, that's not a script, it's a database setting change - are you running that in the database?
I don't know where that error is coming from, it seems to be unrelated to Jira. Maybe if you stepped through what you're doing and told us the handful of steps before you get to that point.
Colin Goudie
July 25, 2013
I believe you can upgrade straight to that version. Make sure you've generted your JIRA 4 license key as they key changed. You can see this in my.atlassian.com
The doc is pretty good in helping you through it https://confluence.atlassian.com/display/JIRA/JIRA+4.4+Upgrade+Notes
thanks for the reply, I'm using that documentation.
I'm getting this error instaling Jira 3.13:
July 25, 2013
Apologies Colin, Angelica - I didn't suggest the direct route because I've tried it a few times and never had it work cleanly.
Angelica Castillo July 26, 2013
Yes, I finally did the upgrade from Jira 3.9.2 to 4.4.5. I had to install the Jira 4.4.5 as a new Jira Instalation in an empty sql server data base, then use the option import data and use the backup that I made for Jira 3.9.2, I added the new license and It works.
Thanks for your help!
