×I use JWM for my procurement projects. The calendar tab gives me a very good and clear overview for the different projects.
My question is if there is a tool where I can add different procurement projects to one calendar? Or even better, if my projects can automatically be added to a meta-calendar, that shows key information for all projects?
if I understood correctly, you should be able to do this using so-called Overviews, which are part of Jira Work Management Premium.
Alternatively, if you are open to solutions from the Atlassian Marketplace, there are various solutions available with very similar capabilities. These often work in and across projects of any type, not just JWM projects. E.g., for calendar views, you may want to have a look at this app.
Hope this helps,
Best,
Hannes
Thank you for you tips @Hannes Obweger - JXL for Jira !
Since I can't find Overviews I'm guessing I don't have the Premium version of JWM.
I am open to other suggestions as well. We have Outlook as our calendar, but I would like to remain in JWM and not mix my Outlook calendar with my project overview calendar.
Guess that really leaves me with the Premium packedge.
