Jira Work Management Training
Bruno Xavier July 20, 2023
I'm looking for training that will help me parameterize the project in Jira Work Management, including the following points:
-Business requirements
-Control of attached documents
-Approvals in workflow steps
-Restricting actions (only members of a specific group can take action in a given step of the workflow)
-Construction of reports
-Flow integration with Jira (end-to-end view)
thank you!
Prachi Bolar
July 20, 2023
Hi Bruno,
Please find the details below.
- Business  :
The main document which can help you in JWM training is https://www.atlassian.com/software/jira/work-management and https://www.atlassian.com/software/jira/work-management/product-guide/overview
For the template : https://www.atlassian.com/software/jira/templates?category=work-management
Please refer to : https://support.atlassian.com/jira-cloud-administration/docs/configure-file-attachments/
- Approvals in workflow:
This is presently not available and we have a feature request for the same : https://jira.atlassian.com/browse/JRACLOUD-62053.
Please find the work around for the same : https://community.atlassian.com/t5/Jira-articles/Add-an-approval-step-using-Jira-Software-and-Work-Management/ba-p/2182531#M7472
Please check this document : https://support.atlassian.com/jira-work-management/docs/what-are-jira-workflows/
Please find the document : https://support.atlassian.com/jira-work-management/docs/generate-a-report/ . This has different reports available in JWM.
Please refer https://support.atlassian.com/jira-work-management/docs/set-up-jira-work-management/ and https://support.atlassian.com/jira-work-management/docs/use-jira-work-management-for-process-management/
Thank You
Bruno Xavier August 23, 2023
Thank you Prachi!
FREE
