Jira Work Management - group by category not working
Jennifer ONeill
For my Jira Work Management project, I created a custom issue type called Event, and custom issue sub-task called Event Task. This has caused issues with the Group By function in the list view and I am unable to group the work items at all.
Trudy Claspill
Are any of you using a Team Managed Work Management project? If so, there is an open issue concerning grouping by categories in such a project:
https://jira.atlassian.com/browse/JWMCLOUD-475
vaidas
April 20, 2023
have same issue, after some time do not have possibility to group by category.
how to solve this issue?
Hannes Obweger - JXL for Jira
Hi @Jennifer ONeill
what exactly doesn't work? Mind posting a screenshot of what you're seeing?
Best,
Hannes
Jennifer ONeill
I have category set at the sub-task level, but not at the task level so it groups everything as "uncategorized". I cannot set at task level, it would be incorrect. Any other way to get around this or the parent must be set?
Miguel Angel April 4, 2023
I've 10 categories. In the past, when I put group by category, it worked. Now, is failing:
