Jira advanced configuration and setup
Vamsi Tirnati
July 7, 2022
We are JIRA first engineering shop in Charlotte, NC. Looking for help with best practices and standards with configuration, reporting and ensuring our JIRA setup is at its best, not to mention being stuck with previous release vs. latest version of JIRA
Anyone in the community willing to help, or advise a consultant who can spend a day with my team?
Thanks in advance
Vamsi Tirnati
Sam Nadarajan
Hello Vamsi,
I am not sure which product you are using, but here's a link to some best practices as documented by Atlassian.
Also, if you plan to use Cloud, you do not need to worry about falling behind on versions, Atlassian manages the hosting and upgrade cycle, so you will always be on the latest version.
We're more than willing to help you here in the community, it's easier for us to help you hear if you provide more specific use cases so we can provide more focused answers. That being said, Atlassian works through a number of partners to provide services. If you want, you can contact one of them here to set up a day with your team.
Hope this helps
