Jira always asks for re-index on all projects
Xavier Arias May 30, 2016
I see the following warning on all my projects configuration:
We recommend that you perform a re-index, as configuration changes were made to 'Plugins' at 26/May/16 1:50 AM. Get help!
If you have other changes to make, complete them first so that you don't perform multiple re-indexes
I didn't make any change to Plugins, so I don't know why should I do the reindex. I've been making a lot of reindexes and I finally gave up, since they continuously popup again every once in a while.
Why is this happening? Are Plugins autoupdating?
Can I reindex all projects at once?
EDIT: I have noticed that I always perform the re-index system-wide.
Dave Liao
Anyone else still seeing this? I last noticed this on an Atlassian Cloud instance, btw.
Tuukka Ilomäki April 5, 2018
We keep seeing it. We have done absolutely no changes in the environment (plugins or other) and still we keep getting this notification.
Dave Liao
I'm also noticing this.
Feature request to Atlassian: after plug-ins autoupdate nightly, allow admins to specify whether they want a background re-index to occur automatically. cheeky
Nic Brough -Adaptavist-
May 30, 2016
Yes, Cloud updates add-ons for you automatically.  But a lot of config actions inside add-ons can require a re-index as well, so it could be something your admins are doing.
You should be able to run a full re-index whenever you want, to cover all projects
I just edited my question to add that I already know how to reindex system-wide.
For the rest, this has happened a lot of times to me and it's a bit annoying.
Could I automatize the re-index process?
Also, I'm the only admin.
Jeremy Gaudet
May 30, 2016
We re-index every Friday evening using a cron job that reaches out to the REST api, and emails our jira-admins group.
For what you say, I assume you're not using JIRA cloud, so you can run cron on your machine directly.
Do you know if I can do that on JIRA cloud?
Jeremy Gaudet
May 31, 2016
You can run cron on any machine, and reach out to JIRA cloud via REST using curl, is my understanding.
Bart Meerveld
October 30, 2016
@Nic Brough [Adaptavist] what if this message appears and i'm on server? Nothing to see in the audit log too.
October 31, 2016
Same answer - a plugin update or field change means it may have an index that needs updating.
