Jira ticket view e.g. /browse/PRJ-58:
So you have the JIRA ticket key in the branch name? The branch will show up in the list only if the key is part of the branch name.
Correct, I do, as Jira generates the branch name for me. However, after creation of the branch, it does not show in the developer pane on the ticket page in Jira i.e. /browse/xxx.
Do you see any error in the JIRA logs while viewing the issue? Anything related to the application links?
Since you are seeing the 'Create branch' option, I assume you have the required permissions.
We are having the same issue but its only certain users.
