Jira and SQL upgrade
Leonardo Vasquez August 20, 2018
I have a Jira environment which database is hosted on a server with SQL server 2014. Jira version is 7.9.2 and is fully compatible with SQL Server 2016. I am looking to upgrade SQL instance from 2014 to 2016.
Do I need to configure something on the Jira server in order to work with the upgrade SQL instance? If I do, what are the steps to configure the Jira server with the upgraded SQL instance?
Chander Inguva
August 20, 2018
Hey Leonardo,
  • Stop JIRA Service.
  • Make sure you have backups of both JIRA Application and Database data.
  • Upgrade SQL 2014 to SQL 2016.
  • Make sure the sql drivers are up to date in <JIRA_INSTALL_DIR>/atlassian-jira/WEB-INF/lib
  • For any change in db names or credentials, update <JIRA_DATA_DIR>/dbconfig.xml with right data
  • Archive all old log files so that you will write all new lines after starting jira service.
  • Start JIRA Service
  • Monitor log file for any errors you might encounter.
  • Log in to JIRA as Admin, check back System info with SQL Version.
Hope this helps
Chander Inguva
Chander,
Can I applied the same for the bitbucket server which is on version 5.9.0
Thanks for you reply
Leo.
