Kindly guide me if some body used jira and hockeyapp integration so that crash reports generated in hockeyapp create issue in jira automatically.
Hey Maimoona,
I don't have personal experience with Hockeyapp but found a resources that mentioned integration with Jira.
If you fully set up integration from Hockeyapp to Jira, and then Jira back to Hockeyapp as described in the articles below, you'll be able to:
Daniel
Thanks Daniel, I used the same links but did the same configurations but not working
