Jira automation fail- Copy a field from destination to a linked issue
Apurva Rathi
April 2, 2024
Jira automation fail - I want to copy a custom field to any linked ticket from destination ticket. This should happen only when the destination's field exists or is not empty. I have used a JQL query to check the same, but it is giving an error.
Marcus Jones
Hi Apurva and welcome to the community! I believe you will just need to add some branching for the related issues. So for example, when an issue is linked, we want to take action on the linked issues so we'll use a branch and set the "Type of related issues" to linked issues. We can then run some Issue Fields Conditions to check whether or not your custom fields are EMPTY or not.
So it might look something like this:
RelatedIssuesBranching_Example_Jira.pngLet me know if I didn't understand what you're after here and hope this helps!
