Jira automation rule to iterate over list and create new issue and link to the parent
shriya July 30, 2025
I am writing a Jira Automation rule which is triggered based on the comment on the parent issue.
Steps:
1. Comment on parent -> vm1,vm2,vm3,vm4
2. Trigger the automation rule on comment.
3. Create new issues for vm1,vm2,vm3,vm4 and link to the parent.
 Problem:
I am not sure on how to iterate over this input and link it after creating the new issue.
arielei
July 30, 2025
Hello @shriya
Why are you trying to base this on comments? it is very dangerous since it will trigger the automation every time a new comment will be set.
i suggest to have a custom field for that, if you have a closed list then use Select Multi value CF.
And then you can iterate on those values.
Hi Arielei,
The input I receive on comment is dynamic and generated runtime by Github Actions.
I have integrated Xray with Jira .
Setup ->  For my CI/CD setup, I am creating "Test executions(Create new issues)" runtime which is based on the "Test environments" available.
Github Actions workflow will check for available "Test environments" and update Jira accordingly. These is based on the information available in the comment.
If you suggest for "Custom field" could you tell me how to go about it in my case?
Shriya
FREE
