  • Community
  • Q&A
  • Jira
  • Questions
  • Jira automation rule with two webhooks (1 incoming, 1 outgoing), which one does smartvalue reference
Laura Guzman March 18, 2021
I've created a rule that triggers upon an incoming webhook, and further sends a webhook via get request. The requests are working, but if I want to access the data from the webhook using smart values, which webhook does the smart value reference? The incoming one or the outgoing one? Is there a way to access the last one (outgoing get request)?
5 votes
Ravi Sagar _Sparxsys_
March 18, 2021
Hi @Laura Guzman
Trying to understand your question. You can access the response that you get from the REST call using the following smart value.
{{webhookResponse.body}}
Let me me know if this is what you were looking for?
Ravi
Thanks Ravi.
I was accessing the webhook data via smart value --> {{webhookData}}
So my question is more about the fact that I'm using two webhooks within one Automation rule. For example:
1. Incoming webhook (trigger event)
2. Filter issues based on Step 1 webhook data
3. Outgoing (GET) webhook
4. Edit issue fields based on Step 3 webhook
Because I'm receiving data from two webhooks, will the {{webhookdata}} smartvalue in Step 4 automatically reference the last webhook data that I got in Step 3, and not the data from webhook in Step 1. This is what I'm struggling to understand so I can better structure my workflow.
Hope this makes sense !
March 18, 2021
So try to use {{webhookResponse.body}} and make sure you select Wait for response checkbox.
Like Laura Guzman likes this
Thanks Ravi!
This worked !!! :)
March 18, 2021
Good to know that.
Ankit Rastogi
@Ravi Sagar _Sparxsys_ I am using two web requests in Jira Automation Rule and I need to fetch status code for both requests in the end of both requests using {{webResponse.status}}. So, I am using two requests, how can I refer separately as I am not sure for which web request status is returning using {{webResponse}}?
