Hi, I would like to create an automation that sends this message to a specific Slack channel
This is the message i wrote but I need to add a function that will show the fields that are empty (if they are empty)
Hi, some mandatory fields are missing in
<https://jira.wixpress.com/browse/{{issue.key}}|{{issue.key}}> Please fill in these fields to complete the ticket.
here are the missing fields: (this is the missing function that I need)
Hi Dagi,
Curious as to why not just make the fields mandatory in the Field Configuration so that users are forced to fill these in upon issue creation?
You can navigate to your project settings, select Fields, then click the edit button for whichever field configuration is associated to the particular issue type.
There you can find the field or fields and make them mandatory.
This article can help explain Field Configurations.
https://support.atlassian.com/jira-cloud-administration/docs/specify-field-behavior/
Hope this helps.
Kind Regards,
Amed
Hi, due to some edge cases (that are not always edge cases) we can't make them mandatory.
do you know what I need to add to the automation's message so it will present only the empty fields?
