×Hello,
I Have a google sheet document where i import my Jira data from a project, but since the last update google sheets seems not recognize the JIRA function. (I have already enable the Jira function in the add on)
How can i do for enable the function ?
Hello @phan ,
I have just tested the =JIRA() function on my side and everything seems to be working fine for me:
However, if I go to the manage add-on page and I look at the feedback, I can see that there were some issues with the latest release and 2 days ago the below reply was added:
Hi there, Catherine from the product team here. We are pushing out a fix that will fix this problem. Thanks for your feedback!
So, it can be the case that you were affected by the same problem, but this is only an assumption for now. So:
Dario
I just uninstall and re install the addon and it works fine :)
