×where do i find these?
Hi @Afrothiti Manolis ,
Thinking you are asking for this info for API calls. This posting may help to retrieve what you need.
This postings should help you to get what you need:
https://community.atlassian.com/t5/Jira-discussions/What-is-my-cloud-id/td-p/900091
-Ben
The simplest way to find your site's Cloud Id is via: https://my-site-name.atlassian.net/_edge/tenant_info
Which, when you replace "my-site-name" with your Jira's site name, will return the following
{"cloudId":"93ac17d7-fe07-4ba3-a53c-5caeb380fff8"}
This is really poorly documented, and the only mention I saw of it was a one liner on the new Forms API docs
^^was the only helpful comment i saw earlier- thanks!
This worked for me. Thanks!
Hello @Afrothiti Manolis
In what context are you being asked to provide the information?
Is there some document you are referencing that directs you to get those items? Is that a document for which you can share the link?
