Jira does not start (plugins have yet to be enabled...)
Raz July 18, 2018
I first time installed jira-server , but when i started it "JIRA-Bootstrap INFO      [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (198):" this is freezing until timeout.
I gived a lot of time for loading plugins but it  doesn't work somehow... I disabled anti-virus  and configured JVM_MINIMUM_MEMORY=1G  JVM_MAXIMUM_MEMORY=2G but still same...
Please help me.
Şükrü TURGUT August 30, 2020
Is there any solutions for this problem.
I had the same issue.
Plugins that have yet to be enabled: (40) and jira server not started because of plugins.
Tried everything.
Alexey Matveev
July 18, 2018
Raz July 19, 2018
Thank you for quick respond, i gived 4000 and none of them loaded :( still says " [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (198)"
Raz July 19, 2018
It can be java version or something in environment variable. I have version 10.0.2 java . Can you share your version and environment variables?
Alexey Matveev
July 19, 2018
Jira does not support 10.0.2. I must be 1.8. You can find technical requirement here:
https://confluence.atlassian.com/adminjiraserver071/supported-platforms-802592168.html
Raz July 19, 2018
Can i use 10.0.2 for netbeans and , 1.8 for jira?
Alexey Matveev
July 19, 2018
You can
Raz July 19, 2018
How?
Alexey Matveev
July 19, 2018
Install two Java's on your machine. set JAVA_HOME to 1.8. Launch NetBeans and choose java path to 10.0.2
Raz July 19, 2018
I set JAVA_HOME  C:\Progra~1\Java\jdk1.8.0_181   and restarted. But still says wrong JVM :(
Alexey Matveev
July 19, 2018
try to execute java -version
Alexey Matveev
July 19, 2018
What is your operating system?
Raz July 19, 2018
windows x64
java - version => java version "10.0.2" 2018-07-17
Java(TM) SE Runtime Environment 18.3 (build 10.0.2+13)
Java HotSpot(TM) 64-Bit Server VM 18.3 (build 10.0.2+13, mixed mode)
Do we need JRE_HOME ? ( like JAVA_HOME)
Alexey Matveev
July 19, 2018
Have a look in the PATH variable. Try to put the path to the java.exe file from Java 1.8 first in the PATH variable.
Raz July 19, 2018
I looked. Java 10.0.2 doesn't written in path variable.
PATH variable has just C:\Progra~1\Java\jdk1.8.0_181   and some others. (not java)
I am not sure i choose the right java 1.8  i setup jdk-8u181-windows-x64 .
Alexey Matveev
July 19, 2018
As far as I remember there is something like java configuration menu option the the start menu. Try it.
Alexey Matveev
July 19, 2018
or configure java. Something like this. You can set there the default java home
Raz July 19, 2018
I fixed Java -version java version "1.8.0_181"
Java(TM) SE Runtime Environment (build 1.8.0_181-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.181-b13, mixed mode)
but still says wrong JVM
I found https://jira.atlassian.com/browse/JRASERVER-59656
If i change check-java.bat it's fixed. But i don't know. What do you suggest ?
Alexey Matveev
July 19, 2018
Raz July 19, 2018
I did same but some how it says wrong jvm . if i change check-java then the error (Plugins that have yet to be enabled) continue.....
I don't know what to do next.
Raz July 19, 2018
I uploaded log file. (JIRA\HOME\log) https://we.tl/bNbw0zLJwT
Maybe it can give you an idea...
Can database do that? I didn't change H2...
Alexey Matveev
July 19, 2018
You have a problem with the database. Try to reinstall Jira from scratch
Raz July 19, 2018
Okay but i don't know how to connect PostgreSQL. Is there an any tutorial or a video?
Alexey Matveev
July 19, 2018
Raz July 19, 2018
You are awsome! Thank you so much!
Alexey Matveev
July 19, 2018
You are welcome!
Raz July 20, 2018
I installed postgreSQL. I used config.bat ( in jira\bin) and test connection is success. But still i get same error.
I really feel in a nightmare.
Alexey Matveev
July 20, 2018
Did you connect your new database to your Jira instance? You can find more info here:
https://confluence.atlassian.com/adminjiraserver073/connecting-jira-applications-to-a-database-861253039.html
Raz July 21, 2018
I think i did. dbconfig file is configured. config.bat says connection is success. when i open psql and test it with \z All has my user.
Alexey Matveev
July 21, 2018
Could you show your logs again?
Raz July 21, 2018
Alexey Matveev
July 21, 2018
I think there is a problem with database encoding. are you sure it is Unicode?
Did you create your database with this command?
CREATE DATABASE jiradb WITH ENCODING 'UNICODE' LC_COLLATE 'C' LC_CTYPE 'C' TEMPLATE template0;
Raz July 21, 2018
Yes i created with that command. I think UNICODE is same. https://www.postgresql.org/docs/9.0/static/multibyte.html
I checked and i see jira did create table in database.
I was installed 9.3 postgreSQL now , i am installing 9.6.
When i setup it, it asked for " select the locale to be used by the new database cluster jira" Can this effect UNICODE ? I am a bit confused.
I updated software but nothing changed. :(
Raz July 21, 2018
I think i found problem. Database has 175 tables but all of them is empty.
SELECT * FROM pluginstate;
this returns empty. Is that normal?
