Jira doesn't start after installation
zvi_rahamim
June 4, 2016
This question is in reference to Atlassian Documentation: Installing JIRA applications on Linux
I installed on centos latest JIRA version,
when I start it (in foreground mode), I get to the print in the log:
04-Jun-2016 20:06:50.858 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
04-Jun-2016 20:06:50.878 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 390162 ms
then when I try to access using the web, it takes couple of seconds and I see another line in the log says:
Killed
Can you please help?
Zvi
Robert Dzido _Almarise_
June 4, 2016
You attached Tomcat logs (catalina.out). Can you check JIRA logs? It's usually file: /var/atlassian/application-data/jira/log/atlassian-jira.log
