Trying to host a jira 7.62 on a windows server 2008 machine with JDK 1.8 installed. Use start-jira.bat and the console stop at :
2018-02-14 12:21:00,925 JIRA-Bootstrap INFO [c.a.j.config.database.Database
ConfigurationManagerImpl] The database is not yet configured. Enqueuing Post dat
abase-configuration launchers on post-database-activated queue
2018-02-14 12:21:00,972 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherConte
xtListener] Memory Usage:
Heap memory : Used: 163 MiB. Committed: 495 MiB. Max: 742 MiB
Non-heap memory : Used: 32 MiB. Committed: 33 MiB. Max: 32 MiB
TOTAL : Used: 195 MiB. Committed: 528 MiB. Max: 774 MiB
Waiting for 10 or more minutes but nothing going on after the previous logs. I have
adjusted the memory setting , but not working.
set JVM_MINIMUM_MEMORY=512m
set JVM_MAXIMUM_MEMORY=768m
What should I do for this case ?
Can you also provide the logs of catalina.out?
what happens when you run java -version on command prompt with the user you logged in?
Did you add the home directory path in jira-application.properties?
Did you try accessing JIRA with http://localhost:8080? Any errors you see on this page?
thanks
