Jira fails to load
Anatoly Fishgang
September 2, 2018
Jira Fails to load,  looks like DB related..
as It's run in a docker, and I've recreated the docker
SYSTEM PLUGINS FAILED TO START: WE HAVEN'T BEEN ABLE TO START ALL THE REQUIRED SYSTEM PLUGINS
We couldn't start the following plugins:
— Jira Projects Plugin (com.atlassian.jira.jira-projects-plugin)
— Atlassian Jira - Plugins - Project Config Plugin (com.atlassian.jira.jira-project-config-plugin)
— Gadget Directory Plugin (com.atlassian.gadgets.directory)
— Atlassian Jira - Plugins - Gadgets Plugin (com.atlassian.jira.gadgets)
— Atlassian Jira - Plugins - Global Issue Navigator (com.atlassian.jira.jira-issue-nav-plugin)
— Atlassian JIRA - Plugins - Quick Edit Plugin (com.atlassian.jira.jira-quick-edit-plugin)
— Atlassian Jira - Plugins - REST Plugin (com.atlassian.jira.rest)
Tinker Fadoua
Hi @Anatoly Fishgang
What' the most recent change you made to your instance? Did you add a plugin?
Best,
