×I am using Jira Data Center version. I have various fix versions in Project. For example : Fixversion is ABC-Jan-23 then ABC Group stake holders to be notified when fixversion is released. I have same pattern for over for another 10 Fixversions. For ex: fixversion are DEF-Jan-23. This case DEF Group stakeholders to be emailed. Similarly ABC-FEB-23, DEF-FEB-23 releases. I would like to email those fixversions when it is released then correspondence stakeholders to be emailed. I don't want to keep changing rules every month. Stakeholders are remains same. How do I use regex ? Or some other way get this achieved.
Hi @Sridhar Gandla ,
you should be able to setup an automation for that. https://www.atlassian.com/software/jira/features/automation
Hope this helps,
Fabio
Hi Fabio, I am using Jira automation. the only thing I am missing is usage of regex. How to use the regex in Jira Automation for the above scenario. It has pattern. for ex: XXX-FEB-23 there are few fixversions are there. When similarly XXX-Feb-23, YYYY-Mar-23 when corresponding XXX, YYY groups to be notified using regex please
