Hello, up to now, as a company we were using Jira without any error. But today we are getting this error:
This page is for Jira administrators. If you're seeing this page, your Jira administrator is probably working to restore the service.
And below there are these lines:
There are the logs of manager.2020-09-25:
And we have increased the JVM_MAXIMUM_MEMORY from 2048 m to 4096m. Nothing has changed. Our current values For JVM_MIN and JVM_MAX:
JVM_MINIMUM_MEMORY="384m"
JVM_MAXIMUM_MEMORY="4096m"
How can we solve this issue?
Hi Günkut,
this looks like a corrupted database for some reason. The log file excerpt does not allow pinpointing the reason - unfortunately, there could be plenty.
From logs there is some probability you are using the in-built H2 database. This is only for evaluation purposes.
In either case, please kindly try to further check with a database administrator on your end. In case a H2 database is in place consider migrating to a production environment.
For the curent setup I'd recommend a restore (if the problem cannot be fixed by a database administrator) and double checking database consistency afterwards.
Daniel
