Important
If you do not know if your back up has an older working data version do not try this.
Warning
Using a backup will lead to data loss! All data between the time the backup was done and now will be lost!
That is a logical assumption i think! You always should have , your data in the same version as the system in which you want to restore them!!!
You can always have a test environment for this!
regards
