Jira ignores changes in crowd.settings
emetriq GmbH
September 19, 2012
i'm just trying to change the "crowd.base.url" and "crowd.server.url" of our confluence installation, because we are trying to migrate crowd to a new system.
I followed parts of https://confluence.atlassian.com/display/CROWD/Migrating+Crowd+Between+Servers and https://confluence.atlassian.com/display/CROWD/Integrating+Crowd+with+Atlassian+JIRA - I did:
  • added all ips to crowd "remote addresses"
  • shutdown jira
  • changed crowd.settings-file "crowd.server.url and crowd.base.url" ( "localhost" -> "crowd" )
  • started jira
it looks like confluence is ignoring my changes, here my User->User Directories->"Directory Configuration Summary"-settings:
Attributes:
    "application.name": "jira412"
    "application.password": (not shown)
    "com.atlassian.crowd.directory.sync.currentstartsynctime": "null"
    "com.atlassian.crowd.directory.sync.issynchronising": "false"
    "com.atlassian.crowd.directory.sync.lastdurationms": "970"
    "com.atlassian.crowd.directory.sync.laststartsynctime": "1348138078105"
    "crowd.server.url": "http://localhost:8095/crowd"
    "useNestedGroups": "true"
How do I change these "crowd.server.url" within jira?
Thanks a lot,
Fabian Zimmermann
JohnA
September 20, 2012
Hi Fabian,
The easiest solution for this is to reconnect the JIRA server to Crowd by creating a new directory, as described in this documentation on the subject. As long as you didn't make any changes to the Crowd application then you can leave that as it is and just reconnect the JIRA to the Crowd.
All the best,
John
