Jira installation stops after database connection
Jordan Baczuk August 7, 2014
I am following the tutorial "Here be Dragons" Stage 1 found here: https://confluence.atlassian.com/display/ATLAS/Dragons+Stage+1+-+Install+JIRA
I am using a ec2.micro Ubuntu instance on AWS. I am able to install all the software and login to the JIRA setup wizard on the browser remotely, and I can even get a successful database connection test. When I click next, it loads for a while and then all connection is lost. I try to log back in at the main port 8080 and it says webpage unavailable. I don't know what happened, but it appears to now be unavailable via the browser. Any help is appreciated.
Pedro Cora
August 8, 2014
Check the load on the server. JIRA does not run on EC2 Micro instances as they don't have enough memory to properly load the system.
Jordan Baczuk August 8, 2014
Thats what I was wondering. Thanks.
What do you mean "startup"? It loaded in the browser and everything. I was able to configure and test the database. Then clicked Next, and it sort of "crashed" I guess.
Nic Brough -Adaptavist-
August 7, 2014
The Jira log shows it's only just starting up, you need to wait until it finishes startup.
I wasn't sure what to look for, so I've uploaded my log files.
(atlassian-jira.log)
(catalina.2014-08-08.log)
(catalina.out.txt)
I didn't notice anything so I've uploaded my log files.
(atlassian-jira.log) , (catalina.2014-08-08.log) ,
Paresh Gandhi
August 7, 2014
you need to look into catlina.out and atlassian-jira.log files for exact errors.
Paresh Gandhi
August 7, 2014
please retag with below if it makes sense
jira jira-installation installation linux
