Jira is not starting after fresh install
Alberto Barros
July 1, 2018
Need help here.
I make new setup running on Ubuntu Server 18.04 LTS.
Install Bitbucket and everything is OK.
After install Jira Software (sudo) and open myip:8080 I create a trial version and I followed the next steps.
Where all done, I see for few seconds a loading page and after that a a blank page.
I uninstall Jira and install again, for this time after load Jira Pluggins I get same problema, blank page.
arikevin July 1, 2018
In your installation folder there is a logs folder.  In there is catalina.out.  Can you post it?
Kevin
Alberto Barros
July 2, 2018
I found this
There is insufficient memory for the Java Runtime Environment to continue.
I chech my server, and I have only 500MB of free memory.
arikevin July 2, 2018
Nice find.  Yeah, web apps, they like memory.  The more you can feed them, the happier they tend to be.  Good luck :)
Kevin
