Jira issue is visible in project board but not through the link in dashboard
Hitendra Chauhan
A new issue is created in a brand new project in JIRA.
With this link the "issue" should open but it doesn't open.
http://myserver:8080/browse/TEST-1
Below is screen print of how it appear when the above link is clicked
image2016-9-28 15:53:18.png
However same issue is visible in project board as shown below:-
image2016-9-28 16:12:7.png
Nic Brough -Adaptavist-
September 28, 2016
Two very quick things
  1. Could you re-index the project and try viewing the issue and the board again?  (Projects have a re-index option near the top right in the admin settings for it)
  2. Do you have any add-ons or hacked-in javascript that might be altering the display?
Hitendra Chauhan
I just re-indexed the project, but no success.
The new project is created in a new installation of JIRA . There are no extra add-on installed.
Also there are no script and I tried by cleaning browsers history and temporary internet files.
September 28, 2016
Ok, there's something badly broken in that display picture, but the only time I've seen it is when you've got a broken index or very broken javascript hacks.
I'd like to have a look at the page (view issue) with a browser dev tool, to see exactly what is on the page and why there's no gap between the header and footer - that might show something.  But if not, then I'd take this one to Atlassian support at https://support.atlassian.com
Hitendra Chauhan
Yes, I just saw there is a bad request in chrome console.
image2016-9-29 11:50:6.png
Now when I opened the bad request url in the browser, the json data says, the issue no longer exist.
image2016-9-29 11:51:5.png
I think, I  should open Atlassian support as you already suggested .
