Jira issue-level restriction
Liu Flame
March 27, 2018
I have two groups (let's call them A and B) for a Jira project. I'd like to use A for project permissions (mainly for 'browse projects'), and use B to create a Security Level and use the Security Level to restrict part of the Jira issues.
My question is, if I configure this way, can I expect the result of it to be:
- If an Jira issue doesn't have a Security Level, the project permissions will be applied (group A will work).
- If an Jira issue have a Security Level, group B will work
Reference:
1. Managing project permissions https://confluence.atlassian.com/adminjiraserver073/managing-project-permissions-861253293.html
2. configuring issue level security https://confluence.atlassian.com/adminjiraserver073/configuring-issue-level-security-861253265.html
Nisha Hajamohideen
March 27, 2018
1.  If the jira issue in the project does not have the issue security level set, then it will be visible to all groups and actions on the issue will be as defined in the permission scheme.
2.  If the jira issue has issue security level set to Group B, only users in group B will be able to see the ticket and the actions on the ticket will be as defined in the permission scheme for the project.
Liu Flame
March 27, 2018
Cool~ Thank you Nisha!
