Jira launch fail after installation
Maximilian Otten
April 13, 2016
I get the following error message when launching Jira following the installation:
Cannot change ComponentManager status from NOT_STARTED to PLUGINSYSTEM_STARTED
Aleks Yenin (Polontech)
April 13, 2016
You need to investigate the JIRA log files from <JIRA_INSTALL>/logs or <JIRA_HOME>/log to get a good clue about your problem. Probably the information you need is at atlassian-jira.log file in the <JIRA_HOME>/log.
Also take a look at this :
https://confluence.atlassian.com/display/JIRAKB/Troubleshooting+JIRA+Startup+Failed+Error
