Jira loads forever when I edit or delete a comment, while I'm an admin.
Arnoud Aarnoudse May 11, 2018
I am trying to remove/edit my comments, but this just makes Jira load forever :( I already tried re-indexing. And I am using the add-on "JIRA Threaded Comments", but this problem applies to normal comments anyway, so I don't think that's an issue?
Brant Schroeder
Have you disabled the plugin and tried the same functionality?  Also are you using cloud or server?
Arnoud Aarnoudse May 14, 2018
I am not sure why but everything works now, maybe Jira noticed it was a Friday, but thanks anyway :) Problem solved itself.
