We would like to support the following custom field inputs.
Issue IS-1234 has 3 configurations. Each configuration has some affected tests.
Can this be implemented in Jira without any plugins? If not, are there any plugins which support this functionality?
Hi @Aleks Vujic Welcome to the Atlassian Community,
What you need is a working multi-level-dropdown-form/qaq-p/2176799 described by @Walter Buggenhout
Go from his fine post and if things do not work out for you, you can always put a specific follow-up question here.
Dick
